      Kyocera 4501i Dumping Toner
      • kleankopy
        100+ Posts
        • Feb 2016
        • 116
        I have at least 10 machines that dump toner all over the registration roller. Have just as many that run fine.
        All of these machines have had new dv units replaced anywhere from 30k to 120k before they start doing it.
        I have tried complete pm kits on 4 of them but it didnt help.
        Also updated all firmware and OEM toner only.
        We clean and pages come dirty again after 10k
        Anyone else see or have this issue.
      • Ropariva
        • Mar 2016
        • 718
        • kleankopy
          100+ Posts
          • Feb 2016
          • 116
          Re: Kyocera 4501i Dumping Toner
          Have not vac out the dev chute and toner disposal filters at the rear.
          I will give that a try.
          • blackcat4866
            Master Of The Obvious
            • Jul 2007
            • 22994
            It's not a cure, but definitely prolongs the interval. =^..^=
            If you'd like a serious answer to your request:
            1) demonstrate that you've read the manual
            2) demonstrate that you made some attempt to fix it.
            3) if you're going to ask about jams include the jam code.
            4) if you're going to ask about an error code include the error code.
            5) You are the person onsite. Only you can make observations.
            blackcat: Master Of The Obvious =^..^=
            • Ropariva
              • Mar 2016
              • 718
              • Phil B.
                • Jul 2016
                • 22798
                I don't about y'all IF I get a call about PQ/CQ after getting the problem(s) explained to me ..and I get my test sheets out.
                I strip the machine of Toner/Dev/PCU/PCDU/Fuser and any 'tray' type parts Duplex etc.
                Then I vac the HELL outta the machine... then gently BLOW the paper path that can't be vac'd
                Inspect each part going back in for wear/build up/nicks/dings make note
                and repeat.
                yeah... sounds a little anal BUT.. how many time have you skipped those step and had to tear it all out again, just to replace a failed dev unit?
                • Scottb
                  250+ Posts
                  • Apr 2013
                  • 314
                  Once you remove the registration assembly and vacuum it out and the copier frame, and the duct at the rear of the machine. You should replace all the duct seals that can be found in the parts book Fig 13 this will reduce the amount of toner dust.
                  • KYO_OEM
                    • Aug 2011
                    • 737
                    look here to find all areas for cleaning
                    • Samanator
                      VIP Subscriber
                      • Sep 2017
                      • 579
                      Thanks for the bulletin KYO_OEM. A big help to show others.
                      • KYO_OEM
                        • Aug 2011
                        • 737
                        look for this additional bulletin for checking if seal modification would done by factory
                        • fishleg
                          250+ Posts
                          • Mar 2009
                          • 426
                          Even the new models still suffer from this just check it if you open the door and notice the transfer roller section looks covered in toner. I think it's just the speed of the machine that does it. Shame all the filters are on the back of the machine. I have noticed the new ones have a vibrating plate in the filter which I've never seen before but I guess it's to keep the filter from clogging up as much.
                          • kleankopy
                            100+ Posts
                            • Feb 2016
                            • 116
                            After cleaning all the filters and the ducts and running for 2 weeks went back to them all and their running a lot cleaner now.
                            Thank you to all who helped.
                              A favorite resort of the foreign residents of Yokohama during the summer months is the island of Enoshima. It is about twenty miles away, and is a noted place of pilgrimage for the Japanese, on account of certain shrines that are reputed to have a sacred character. Doctor Bronson arranged that his party should pay a visit to this island, as it was an interesting spot, and they could have a glimpse of Japanese life in the rural districts, and among the fishermen of the coast. "But as we are in for it," he continued, "we must make the best of the situation, and hope to go through in safety. Many a strong ship lies at the bottom of the sea, where she was sent by just such a storm as we are about to pass through, and many another has barely escaped. I was once on a ship in the China seas, when the captain told the passengers that it would be a miracle if we remained half an hour longer afloat. But hardly had he done speaking when the wind fell, the storm abated, and we were safe. The typhoon is to these waters what the hurricane is to the West Indies; it is liable to blow at any time between April and September, and is often fearfully destructive. OPIUM-PIPE. OPIUM-PIPE. "Surely your ladyship knows Dr. Bruce!" Hetty said with a vivid splash of colour on either cheek "A little time ago I understood that Dr. Bruce----" "I require that everywhere a strict investigation shall take place into the conduct of the soldiers with regard to the life and property of the civilian population. "Where were they buried?" They all pressed forward. "Count out. That's the only fair way," shouted the boys in the center. "Now, there's three loaves o' bread for the Sargint," said Harry, laying them down on a newspaper. "There's three for the Corpril; there's three for me; there's three for you." "'T?un't peas, thick 'un," Vennal would break in uproariously, "it's turnips—each of 'em got a root like my fist." At this moment of perplexity, some medicine, that she had obtained from Edith, occurred to her, and, with a feeling of confidence, and almost of extacy, she took a phial from a shelf in a cupboard where she had placed it, and, pouring out the contents in a large spoon, hesitated an instant ere she administered it. "Let me see," said she; "surely it was a large spoonful Edith told me to give—yet all that was in the phial doesn't fill the spoon. Surely I can't be wrong: no—I remember she said a large spoonful, and we didn't talk of any thing else—so I must be right." But Mary still hesitated, till, hearing a sudden noise in the court-yard, which, she conjectured, was her mistress returned, and as the child was getting worse every moment, she leaned back its head, and, forcing open its mouth, compelled the patient, though with difficulty, to swallow its death. The draught was taken; the rigid muscles relaxed, and for a minute the child lay motionless in her lap; but in an instant after, Mary could scarcely suppress a shriek at the horrid sight that met her gaze. The eyes opened, and glared, and seemed as if starting from the head—the fair face and the red lips, were blue, deepening and deepening, till settling in blackness—the limbs contracted—the mouth opened, and displayed a tongue discoloured and swollen—then came a writhing and heaving of the body, and a low, agonized moan: and, as Mary looked almost frantic at this dreadful sight, Edith's words, when she had given her the phial, "that there was enough there to kill," suddenly occurred to her—and then, too, came, with a dreadful distinctness, the remembrance of the true directions which Edith had given. It was nearly noon the next day, when the under-sheriff entered the room to ask if their opinions were yet unanimous. The galleyman still refused. "That for ye, coward," said Tyler, striking him with the flat side of his bared weapon. Oakley aimed another thrust which was again turned aside, and the smith, now flinging down his sword, seized upon his right hand and wrenched the dagger from its grasp. After a short struggle, Oakley fell heavily on the pavement with the blood streaming from his mouth and nostrils. HoME萝拉泷泽第4部资源 ENTER NUMBET 0016www.gzpzqc.org.cn
                              kzchain.com.cn
                              www.gersnq.com.cn
                              www.rzeqnm.com.cn
                              www.modg.com.cn
                              www.qfw810.org.cn
                              qynytech.com.cn
                              t51d9.net.cn
                              pwchain.com.cn
                              www.xapycw.com.cn
                              百度影音成人区图片 操人体模特 日本熟女被操图 最新av片 大阴唇自拍日本熟女人妻 性福男自曝夜夜销魂有诀窍 三极伦理电影 李宗瑞性爱视频影音先锋 无码最漂亮女优 强j乱伦小说 三级视频淫b内射 ooxx的日本动画片 亚洲14p图片 肉穴姐姐的衅 26uu 第四色米奇影视 欧妞色穴 先锋影音2015欧美 国模柳青青 狠狠干综合网bt 色蝎子 交换妻子米奇影视成人社区百度影音 特别刺激的人体艺术 艹小姨子嫩b 我的黑鸡巴毛长出来了 欧美性爱野战 我要插黑丝袜 性爱自拍第一页 seba 色哥哥 15p WWW_MMK_COM 李宗瑞视频要下什么播放器 冈孝 老师和我 h漫 美少女逼图片 老头老太太性自拍 美阴图 色播吉吉影音网站 坐爱dongtai 黄片马与驴 撸 色图 性 伦理小说迅雷下载 美女大胆下阴摄影艺术图片 男子身体艺术 同事 妈妈 强奸 妻子 野外乱阴 成人动漫哥哥射 鐖鑹插爞鑹插浘 黄色片艺术照 轮奸乱伦黑丝 明摸显示生殖器 熟妻影片 熟女 波霸电影 欧美老女人露阴艺术 WWW_ADULTRAY_COM 肥熟胖骚15p 国产夫妻交换磁力链接 欧美黑人男阴茎 男人舔逼动态色图图片 人体艺术 肥佬影音能看哪些网站 卡帝兰是真是假 京香julia人体写真 淫荡二嫂 ilovekao 表妹性爱小说 欧美bt下载阳具 美女版小苹果 哑巴生煎 聚宝盆下载 qsw444 校园春色小说网色妹妹 男女为什么要日屄 bb图片操几把 日本成人影院迅雷下载 WWW_VZV8_COM 拜访欧美av的那个男人是谁 younuxaoshuo 雨宫琴音亚洲动画自拍気になるル━啷幞ぅ? 欧美的性感色图 未成年男孩和女人性交 宫间葵无码ed2k 亚洲色图操妹妹 京香影片图片 边久轮珠 � 林心如两腿分开 饭岛爱快播电影网 石川优季奈吉吉影音在线播放 伊在爱大胆高清人体艺术 草老比小说 张柏芝丝袜 电车痴汉种子华为网盘 日本咪咪性交图 和邻居交换母亲 人体艺术舍摄影 厕所里的黑丝袜 桃花源小说图片综合网 WWW_310DD_COM 快播色妹妹小说 日本幼幼番号 123操b 老师的淫逼 WWW38XTCOM 睡觉的女人影音先锋 骚妇自慰乱伦在线视频 色姐姐快播网 叔嫂性爱故事 欧美老妇老肥b 嫩屄bi 狗哥哥肉棒 半夜到野外口交射嘴裏 和熟女性爱视频 美国少妇人体图 换妻爱爱爱 邓紫棋图片亚洲色图偷拍自拍 张筱筱大胆人体艺术 第四色gao 国嫩逼掰穴图片专区 操操妹妹撸 搞老太影院 熟女自拍色图 三剑侠与飞机妹色网 十二岁幼幼性交 亚洲包色图 美女被插到高潮 丝袜少妇兽交 换妻多人群奸小说 吞精乱伦 夫妻性姿势真人 女童口交性爱影片 东北老太做爱视频 亚州合成色图 武汉17中教室门吉吉 狼国成入网无专软件 qvod2008黑暗体操 av日本美女口交黄色电影 曰本黄调 五月香福利网fulipaoinfo 李宗瑞三级片快播 长谷川里约 欧美视频另类酷文张飞跃 谁有黄色免费的网址2014 奸淫荡女教师 亚洲在线极品无码 性爱先锋黑人 小说我的乱性生活 东方av影视 欧美丝袜美女无码ap影片在线观看 舒淇人体艺体 八零后操屄 毛家湾科目三考试视频p99350103 姐妹性尻图片欣赏 真实夫妻网络做爱大秀录像 色k播播 这个被操的嗷嗷叫爱色网 色老师小说合集 人人操视频成人 姐姐被狗狗操快播电影 70岁老太性交电影吉吉y kedowuo 我的鸡巴在唐嫣的逼里面抽插 欧美性感老妇女自慰 猪猪影院oooo猪猪影院 xxxj动漫版 强奸伦理片 ady幼儿性交 人休极品摄影 丝袜美腿搞射 透明人体艺术图片 大王不容易天狼影院 性欲淫妇 爱好群交的丝袜 操黑丝淫妇 欧美撸幼女 jjjjcom日韩新片网 日本无码电影访问升级 kunbangsetu 青青草在线福利视频精品 尾行3无打码视频 pornhub纲手 SW444女子病房痴女们的性欲 适合女生看的AV百度云 猫咪av最新网站百度 李毅情趣小说 淮南熟女 调教女学生安娜 世界上超爽的黄片 干别人老婆嗯啊小说 mm挀腿露b 岳母的蜜汁 欧美妇人与兽视频 小女孩含住小鸡鸡 亚洲色图综合图库 日本女忧的感情生活 外国美女一级黄片儿 日日干澳门 奇色手机影视 wwwse94s4gmailcom 护士骚妻的巨乳奶水www001bzin 韩国伦理片pornsex swww290sihuco 考波波网 花心撸 52jjjj巨乳 小次郎裸女郎 操女生的阴毛 黄色片海滩 日本苍井空黄色网站 草芦TV 色天使成人电影 狠恨爱加夜夜射 天下第一色网址排行 三级文学网 狐狸成人电影 亚洲色色图www23mmmmcom 淫淫www38jwcom jiatingluanlunavtt 欧美黑人无码手机在线wfdfqmsnhpcn 丝袜自拍露脸套图 帅哥和妈妈在沙发上 足控狼友 快播日本乱伦 柯南泡妞录 三浦麻衣 男女房中术牲交时男女自述高潮过程 兰桂坊戌人社区 上海浦发论坛 tokyohot亚洲激情 色妹妹黄片网 内射吞精小说 26ccc第四色 骚姑娘操逼 处女的小蜜穴 WWW38路C0n 婷四房色播 超碰网址小说 韩国黄色网站百度 变态另类继母 百度酷色酷 www69vidsinfovideos 巨乳波霸动画片 wwwfuli123m papakiss freeporn地铁痴汉 淫棍激情小说 起笔屋 226bbbcom手机网址 yyaaVvmagnet elluxurycom 偷拍处女乱伦人妻亚洲欧美 黄色一级片女人吃大鸡吧 操碰最视 免费公开VIP视频 swwwshouma520sexinsexnet 私穴美鲍 肥老夫妻自拍 强奸社长qvod 淫色电影人与兽 优优全裸av美女人体艺术 男男激情ed2k 最新国模人体艺术 新欧美足交性爱 花井美纱种子全集 新renzuoai 鲍鱼自摸偷拍自拍 五月天艺术裸体 母子野外交尾 求三级片下载 奇米影视苍井优 av韩国MP4 www22bbbcom免费电电影 av影音先锋中文字幕 色七七影视 美女做爱自拍图 和表妹做爱-百度 激情av成人在线 男人装五月 第四色夜夜射五月天 绝色家族1~5视频 雅篾蝶综合网 男男互日小说 久草视频无码中文字幕7l66com 奸入女儿 岛国无码AV免费视频 男人爱打四色 wwwepornercom 激色五月 交换女儿插小穴 老人与孙子乱伦 夜奸爆巨乳女老师 赵莜雨人体艺术 新版1024基地 肥胖女人快播 热久久303青青 单男久久在线视频 在线观看的h站 成人电影AAA990 无码一级黄视频 WWW_SHOPEBDOOR_COMSHOPS 各种女人b的样子图片 美国性爱导航 成人电影tom西瓜影音 淫色帝国成人电影 动漫成人图片网站 55550666 骚片视频免费 丝袜护士成人 高潮内射风骚淫可园 淫电影网 wwwy6w7c0m av天网堂2015 使用q播的电影网站 97惰色在线观看 韩国电影谎言下载地址 www860uucOm 亚洲图片偷拍视频区avav78com wwwsusu27magnet wwwcc364 曰麻比 www150co 无毛小穴 a∨ 抽插良家少妇人妻 青娱乐吧全部视频 色人格高清 女神遥手机在线播放 日韩幼女av 不需下载在线观看操逼短片 姑坏姑集百万潮流 局长成长史686 操我在线观看中字 撸撸鸟系列 男人第四色网 妹妹成成人电影 国产淫淫网 千百撸制服丝袜 算你色98 sff636com 好xxoo永久视频观看免费 百性阁mecom 裸女图片全身不遮无马塞克 国产搞ba片 se1000 日本成人综艺在线av 东方av亚洲图片欧美图片bbcc789com 法国成人在线 两性人体模型 强插人妻10p 哥哥撸妹妹湿在线影院 摸摸插插爱爱 99re6久久热在线观看3 www99hh 和谐色网 搜索去色色吧 爱裸睡的女儿丹丹 av色老太老汉 男人的大鸡巴操操 全国黄色片子 7ccc人体 3wbbbcom 搜索www76vrcom 狐狸精影院AV在线 成人撸一撸小说 大香蕉色一本道色一本道 清纯唯美88ttile88 色网色妹色姐姐 AV视频直播 与末成年美女性交 和阿姨疯狂啪啪3p 变态另类SM小说 校园校园春色制服诱惑强奸轮奸 成人快播网址大全 色姨妈 姐也要蝴蝶谷 AV资源网站免费在线观看 欧美幼女被干快播 117gaocom 欧美性爱小说之成人电影 欧美性爱人体艺术做爱动作 男女性爱三级毛片 性爱技巧熟妇 欧美性爱免费在线播 卡通动漫调教家政 啪啪情 吃奶我看逼 日本成人图片小说ed2k av长片在线看 丝袜日本美女小说 影音先锋少女肉便器 狠狠撸娱乐网种子 nn912CoM 老婆被两个大伯轮 2015蝌蚪窝超碰视频 911vv 小明看看免费imgcctuocom 少妇嫂子p 自拍大香蕉视频网 舔b在线电影观看 幼女的小嫩穴色图 亚洲色图校长 爱色岛丝袜 久久综合色a 沈阳母子 成人电影亚洲欧美偷拍视频网站 uzzjj 偷拍自拍图片人人 曰了电影明星 鸡吧撸 三级黄色小说激情都市都市淫乱都市激情 附身黄色小说 五十路丰乳肥臀的熟女 欧美电影第1页wwwluav7com 日韩息子av 第七色影音先锋大片 情趣网衣种子 swwwsexoquentetv 2017来个成人网 高清韩国中文字幕在线观看 哥狠狠狠狠碰 猛操侄女的骚逼 想屄图 欧美色图 大黑逼 地下歌舞团黑酒吧演出 妻子成人小说 光亲嘴电视剧 超级碰成人在线视频删除 妈咪色五月天 13岁小萝莉裸体艺术 强奸共妻小说肉文 亚洲综合av 插妹子人体 淫荡的插逼色图 淫妻小说日本做爱 和老女人尻屄 吃女人逼 西西大胆国模人体 陈静裸体照 我教女儿和丈夫做爱 谁有日志里带黄色电影的 ady黄色图片 美女下部曝光 插射馒头逼 妹妹爱吃大鸡巴 关于大胸美女做爱的片子 屄的图片 欧美人体艺术 美鲍 乱伦咪咪色 操丰满的护士 模特阴毛人体 在线视频欧美亚洲酒吧 美女被干黄色无遮挡图片 偷拍自拍911av视频在线 女学生肏屄 欧美性爱亚洲色图在线迅雷 女儿的奶水和妈妈做爱 恋老网老牛吃嫩草视频 天天干女人手机kahao快播综合网网 老年夫妻爱爱 动漫女孩怎么插第3个 欧美风骚熟女淫荡大奶骚妇被插图片 人体自性爱小 03ssss电影 少女的b上没长毛的b 公狗和美女操逼小说 玲真丙 mm粉嫰的黑木耳18p 挺入屄小说 h狠撸乱伦小说 白皙亚裔女大战老外 台湾电影演员李xx dianyenglianggenuren 97淫 干淫妇 漂亮空姐被痴汉干了的性爱文章 美女和狗操比 偷偷录香港黄业 六九av视频 裸体少女的洞洞 对不起英语 榆林市第一中学 3g软件 天龙八部33 东南亚女孩艺术人体 性爱妹妹在线视频 强奸人妻视频mp4华为网盘 偷拍性美女 大尺度做爱 美人阁第四色 亚洲射图2014 WWW94SSSCOM 色久久哥哥干 小姨子屄好大 fu1010青青草 少妇熟女色图撸大妈 美女裸体全图动态 裸体美女人体艺术b 欧美肥婆色图10p 合肥丝袜 激情操比 2014最好看的lunli电影 囗述被强间 乳房摄影 欧美小女孩h吧 就要肏屄 小岳母的淫水 成人短片视频自拍免费 欧美巨乳波霸性爱片 学生妹被老师 欧美图片很很操 阿姣冠希 田村正和近期照片 亚洲欧美2岁幼女 插咪逼逼 不卡成人在线视频 骚逼超碰在线视频 巨乳人妇小说 老婆嫩穴10p生活 亚洲色姐妹图片欣赏 日韩明星性爱色图 色和哥哥 兽交幼女影音先锋播放 狂插大逼95 内射熟女30p tpimage久草 我老婆的骚肉洞 五月天激情成人爽片 插逼里动态图 淫色淫香影院 影音先锋av撸色人妖 韩国网站导航 美女喷乳 超性感淫乱美女教师 韩国漂亮姑娘全裸性交微电影 丝袜26uuu银川18岁 撸撸淫色图吧 操苍井空嫩屄 都市种马母子禁忌小说 嗯啊草屁眼影视先锋 色猫av电影院 儿子伦妈妈小说 干熟女亚洲色图 人与动物法国zo0 成人a片播放1哥哥插妹妹 操熟女老师 欧美男女性交自拍图片 sm捆绑撅屁股 你懂的卡通电影 小姨的内裤湿了 婷停五月深爱五月wwwaaa366com 夜勤舶成人动漫快播 大鸡巴老公 OOOXXX夫妻绳艺mxhamstercom lulnulu石家庄 爱情动作小说网站 韩国美女主播阿里快播 Wwwm7lulucom 大肚子肛交 涩涩淫淫 chaopengsepian 拍妹妹拍哥哥射 好滑的逼逼 明步终极诱惑 激情五月开心五月丁香五月在线电影 类似菲菲影视城 美女骑兵社区 绿帽女教师 色图片孕妇 苍井空点影 成人毛片中国 wwwjjzzzcom yy6080网站图片 klk重口味 爆菊花影院经典三级 韩国女主播导航网站 美女意淫自摸视频 白洁激情黄色成导航 japanesevr在线 粉色国外成人小游戏 Www835xycow av视频免费观看全集fg1netcn 天天操天天干超碰在线视频百度百度 wwwxxxcommxxxnxxxus 小穴好嫩电影在线 ww52avavwww722hucom 女虐男h小说 操av社区亚洲无码 超碰视频大家还在搜 啪啪啪吃乳 学妹嫩b 西西人体艺木删除 wwwmumubocom 韩国电影青苹果西瓜影院在线观看 欧美裸体Av图片 qinglvzuoaizipai xxxgmailcom 龙口护士门福利社区 加勒比海盗3快播 天天色www444nenecom c19090be00026fe8 无毛美女姓交 仓井空bt种子下载 强奸系列成人小说 男女有声小说 丽苑春色图 荷塘春色图 春色夜生活 春色满人间 红花樱井莉亚avi 樱井莉亚误上贼船 小泽玛利亚2穴 小泽玛利亚vod h网小游戏 快播无毒h网 给个能看的h网 电影h网 加www访问 开心热爱五月天 东京热图片网址 东京热天使 永泽真央美 色护士影院 夜色青楼巷 007成人网 秘密花园论坛 婚外的自由性愛 10movs视频 色大姐 同涩限制分级 色人间阁 很狠撸 2019av无码无线免费播 草青青a级 骑兵影院 喜爱在线 二区 ppyydz变成什么地址了 最新sq网站 日本AV0923 天堂av8 福利社 都市激情 store丹尼尔斯AV在线播放 综合网王 着衣佐山爱 au天堂网 每天在线更新观看奥av首页 cao250som 不要向下看天天影院 2828电影网金瓶艳史 3d成人视频 182tv 青青草 日韩亚洲影视A片 清新影院 视频怎么看全部 青青草原AV苍井空 小老弟影院发布 秋日天空电影 秋霞电影qiuxia71 青霞成人伦理电影 情陷曼哈顿第几分钟 日韩在线毛片视频 幼幼操吧 日本摸奶酒吧电影 日批神马电影院超九电影 日本免费视频荡妇 www5151HHCOM 国产自拍打底裤在线观看 免费成人性交 影院电影手机观看综合网 色和尚,狠狠日 美利坚在线黃色视频 mp4 小泽玛利亚作品在线播放网站 东方后宫东方a 日本鲁鲁片在线观看 私库东京热免费视频 绝品尤物!女神级别超美妞,疯狂3P现场,淫荡满屋! 足交丝袜视频在线 乱伦性爱无码视频 论坛 亚洲 欧美 自拍 国产 亚洲妻 wyn之萝莉护士的情欲 午夜福利啪啪在线观看 彩美旬果最新作品 mp4 青青大香蕉97在线观看 催眠控制迪丽热巴成为女奴 网友自拍分类在线观看 国产3p 在线 天天啪啪啪天天干 成人网站免费无码视频 日日在线操小妹视频 家事偷情福利 韩国主播孙艺贞 嫩中学生magnet 旧谷露影院av欧美 日本护士AV色 护士兽性新人类 天天色好好日 avavavavavav百度云 亚洲老太视频在线 孕妇做爱的av视频 日本A 白丝av在线免费观看 JA∨一本道 色东方 97人人射妻 超级特工 ftp mmm、fac688 色综合黄色 av更新通知 爆乳天堂AV 亚洲天啪 SOE-422uncensored 顶峰视频熟女 激情 大香蕉tv不卡在线视频 大香蕉视频av中文字幕 爆乳肥臀魏征 日逼视频免费看完 日本男女做爱3p 三级片小护士 妓院Av 桥本舞无码AV磁力下载 每天更新偷拍自拍视频的网站 吉泽明步 video ggmmkk 777selu 深情 五月天四房播播 成人电影数字。 免費視頻av 欧洲成人在线 91hdav101高清女优在线 亚洲免费激情视频 做爱小事频 狼人久久操 日韩538pom 孕妇视频XXⅩ 成人偷拍AV视频 九七成人在线视频 35ago好吊视频下载 日本摘花破外免费视频 年轻漂亮的女孩大尺度淫荡自拍小合 cop在线视频 外国里番网站在线观看 汤姆影院在线观看co m 五福影院av地址在线观看 uu729 噜一噜噜色2015最新版 你x我x网欧美网 日本人体艺术影院 4438成人电影 西瓜影音 东方在线改名 青青草激情明在线观看 综合 美少女 帅小伙抹点润滑液 波多野结衣性爱无码在线 98kkbb最新地址 黑丝丝教师视频曝光视频 超短裙女教师 肏丝袜 黄瓜99u2视频 www1769zy1com 19+韩国 东方影厍四虎 老师影院一级 日韩福利视频在线 日本全球最大的69性爱视频免费 97色色免费视频观看 黄色查逼 丝袜护士激情做爱视频 白洁 高杰 朋若妻 韩国十九十禁女主播在线观看 川菜美铃资源 色站导航丁香色 www,3232,con av12中文网 天堂www65bxcom网站 a v天堂v电影亚洲v 开心五月狠狠干 丝袜无码系列130 AV饰品 蝌蚪窝居 东方Aa视频 好屏日视频53sao com 同牲 激情综合网俺也撸 17i 小学生性爱视频。 69堂视频最新客户端 小视频帅哥要乳交吗 新婚少妇 偷拍自拍 小纯洁社区以我而存在 校园春色 激情视频 鲜嫩福利视频 小明女优视频 奇米第四色 西瓜影音 日本激情戏视频 87福利伦理在线 av番号在线直播 狂操空姐嫩比网 廉租房里草干妈 在线歌舞团福利 中文撸撸国产自拍在线 唐人电影av 桔子av资源 找av123导航 52avav路com www 日本人性交啪啪啪视频 欧美大屁呼性爱视频 裸体睹场视频在线播放 中日素人制服视频播放 日本床戏在线 鲁大妈va大香蕉 性感韩国美女主播叫床 法克小视频刘亦菲自慰 黄色视频高潮 荡女报恩亚洲视频 松岛枫 潮吹便器无码 秒开资源免费观看福利小视频 国外破处视频hd porn在线播放制服丝袜 天海翼gar 轮奸路边小骚货干完还一人一泡尿迅雷 1琪琪网伦理片性之道 偷拍自排福到女主播野战合集 nb色播 亚洲色欲色欲www一本道 蚂蚁窝 西瓜影音 水菜丽无码粪便av连接 草裸影院 韩国成人主播 操BxX成人是免费视频 国产自拍gv 操逼段短视频软件 爆乳美女口交颜射在线 国产偷拍洗澡视频种子下载 草比视频福利视频 亚州欧美成人 手绢叠生殖器 茶水影院 操空姐小嫩穴影视 猫兔AV手机在线播放 病态爱慕百度云 超黄的操逼片 人人爰一大道大波女 嫩模福利宅男影院视频 wwwmmm3333com www1hxhxcom 快播麻辣影院 无码av手机秋霞 pp268C0m 啪啪影院8090 天天啪天天碰香港 三七影视成人福利播放器 免费观看欧美大片毛片 请放黄片看看 av人妻视频 影音先锋强奸乱伦在线看 裸条网站 人妻推精油视频 裸少女影院 男人懂得电影天堂 asia_fox 试看的黄色短视频 男女作爱后插鸡 蜜桃成熟时1997 电影 午夜福利五十路 小早川怜子伦理 2018国产欧美在线va 红帐房偷拍女神级漂亮白嫩的大学美女第一次和男友啪啪时被直接内射,把女友气哭了 手机视频福利在线zxfl 国产综合 本田英里子先锋 操逼视频在线无码 被窝电影网 七七影院 电脑版免费A片 最新国产群交视频在线观看 刘可颖视频在线播放 快播骑兵 国产网红主播激情自拍 大西瓜视频qropm Avtt2018天堂网 日本做爱全集 琪琪影院手线无码 另类sm专区 不穿内裤运动无码 国产偷拍 口爆 亚洲经典 aav手机天堂 影视色 黄色人体视频 gav网 可可和教练 迅雷链接 新人三级伦理 mp4 国办自拍 优优色影院 偷拍自拍 范冰冰全裸毛片 hhijibacaonenbishipin zaixianxingaiyingpian 国产成人自拍免费 欧美肥臀女做爱视频 48qa铃原爱蜜莉 肥臀丰乳少妇视频 乱伦视频在线免费看 丘哾爱米莉步兵电影 混血哥双飞姐妹花 精子窝在线精子窝最新地址 强力炮抽插小穴视频 奸你视频 强制 耻辱 mb 无码 教室诱惑夹笔杆番号 强吻小视频软件不用下载在线观看 无码wwwchaye518cn 老女自慰 色色女人香 小岛南ZAIXIAN 偷拍 亚洲 在线 电影 乱伦 小说 内射流白 不橹三二一 piapiapia床戏免费视频 干丝袜女视频 老头强奸处女 寝取部在线观看 一级a爰片免费免会员 微拍福利老司机 雯雅婷3d动漫在线观看 手机在线一本道成人电影 日在夏天 海棠哥帮学妹补公课 红番阁午夜影院未满 黄片《慰安妇》视频 欧美孰妞 老司机影院谷歌 最新韩国一级片播放 变态另类变态性虐 乌克兰黄片番号 岛国色色视频 人体艺术伦里 互日影视 亚i洲在线 校花门迅雷下载 丝袜女同性恋接吻女子磁力 泽井芽衣Gif卵蛋蛋动态图新地址 看吧av 东方色 妻不如妾av自拍 完熟 av 湿妹影院费一分钟 h动漫高清无码番号 迅雷哥北原多 欲情希 126bar自拍 欧美操小浪逼视频 国产第一福利视频在线观看 扣阴视频。 福利视频IO00 饭岛玖罗视频在线观看 国产高清针孔偷拍 抽插式爱爱视频 好吊操清平免费视频 国内偷拍伦理片 国产自拍在线一区 好屌福利视频 韩国女主自慰 magnet 好屌淫。 国语日本电影 俄罗斯一级av黄片 国产微拍偷拍种子迅雷下载 漏屄日屄视频 国产直接 国产自拍啪啪啪论坛 自拍视频1717射 操逼视频 日本 抽查蜜穴视频 色妻在线手机视频 女同视频dj AV字幕网 日本动漫高清无码黄色 爱诱欲 magnet 大香蕉在视频在线1234观看 免费黄视频在线观看 69堂嫂子吧 不雅视频磁力链接下载 jux-540 中国富婆调教在线服务 美女大肥阴户露阴图 亚图人妻剧情日韩 外国女人的比为什么总是没水 媛交女教师百度影音 大黑鸡巴猛插骚逼 老外大鸡巴做爱 日本人体美术 李宗瑞性侵论坛 哪里能看到乱伦小说 人体艺术图打包下载 人与自然动物黄色片 988大胆人体艺术 日本推拿师偷拍系列 黄色小说说的是哥哥上了妹妹和妹妹的同学还有个地下乱交的舞厅 咲子さんノ男性事情2 人体私拍海天翼 小泽玛丽亚7p人妖乱交 山本未来的吻戏 人兽肉文 亚洲套图欧美套图偷拍 大鸡巴狂插不射 天王影音黄色电影 美淫母亲的秘密 gege揉搓 自拍偷拍综合网 迅雷下载操逼动画片
