If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
I just acquired a used MP C3004 copier. I successfully connected it to the WiFi network, and I can browse web pages through the control panel. However, I cannot find the machine through the network. There are other WiFi printers on the network with the same settings which work just fine. I set the IPv4, subnet & gateway through the control panel, and it shows the proper settings on the control panel. However, when I print the configuration page, it indicates that the IPv4 is 11.22.33.44, subnet and gateway are both 0.0.0.0. When I set it to auto DHCP, it also sets the IPv4 to 11.22.33.44. So somehow it is not writing the settings to the ROM. I cannot connect through the Web Page Monitor because of this issue.
Sounds like you have successfully setup the WiFi of the Android OS of the control panel. It does not have access to the main frame functions. Unless the C3004 has Ricoh's POC add on WiFi interface what you are setting in the interface settings is for the wired connection. 11.22.33.44 is what you get when it can't find a DHCP server. If you do not have a wired connection available you can either spend a few hundred more for the WiFi interface option or you can use as AP extender, some are less than $30 US.
Agree with slimbob. The wifi settings for the android display are irrellivant. Most likely you do not have the wifi option in this machine. Plug an ethernet cable into it and start over.
I have a WiFi extender at home which is what I was considering to try as a stop-gap measure. My ideal connection would be able to have air print capability. Thanks for your quick reply. i will have to look into the WiFi interface. Is that the board that plugs into the area by the connections near the back of the copier? If you have any direction on sourcing of this board please let me know. I really appreciate your help!
I set up the WiFi extender and I can successfully connect the Ethernet cord to a desktop with the WiFi turned off. Everything works as expected, and can access the Internet. When I plug the same cord into the copier, I get nothing, even though the LED is on, indicating a connection. Is there some master reset process for the machine to bring it back to factory settings?
Things are working now. I ended up making all protocols inactive, rebooted the machine, then made them active one by one. It only works with the Ethernet cord connecting the copier to the WiFi Extender and also the copier connected to WiFi. It now stores the IPv4 address and subnet in the ROM and prints out correctly on the configuration log. It will print wireless from laptops, desktops as well as the ability to AirPrint from Apple devices. Hopefully that will solve things for good. Thanks for your input and prompt help!
A favorite resort of the foreign residents of Yokohama during the summer months is the island of Enoshima. It is about twenty miles away, and is a noted place of pilgrimage for the Japanese, on account of certain shrines that are reputed to have a sacred character. Doctor Bronson arranged that his party should pay a visit to this island, as it was an interesting spot, and they could have a glimpse of Japanese life in the rural districts, and among the fishermen of the coast. "But as we are in for it," he continued, "we must make the best of the situation, and hope to go through in safety. Many a strong ship lies at the bottom of the sea, where she was sent by just such a storm as we are about to pass through, and many another has barely escaped. I was once on a ship in the China seas, when the captain told the passengers that it would be a miracle if we remained half an hour longer afloat. But hardly had he done speaking when the wind fell, the storm abated, and we were safe. The typhoon is to these waters what the hurricane is to the West Indies; it is liable to blow at any time between April and September, and is often fearfully destructive. OPIUM-PIPE. OPIUM-PIPE. "Surely your ladyship knows Dr. Bruce!" Hetty said with a vivid splash of colour on either cheek "A little time ago I understood that Dr. Bruce----" "I require that everywhere a strict investigation shall take place into the conduct of the soldiers with regard to the life and property of the civilian population. "Where were they buried?" They all pressed forward. "Count out. That's the only fair way," shouted the boys in the center. "Now, there's three loaves o' bread for the Sargint," said Harry, laying them down on a newspaper. "There's three for the Corpril; there's three for me; there's three for you." "'T?un't peas, thick 'un," Vennal would break in uproariously, "it's turnips—each of 'em got a root like my fist." At this moment of perplexity, some medicine, that she had obtained from Edith, occurred to her, and, with a feeling of confidence, and almost of extacy, she took a phial from a shelf in a cupboard where she had placed it, and, pouring out the contents in a large spoon, hesitated an instant ere she administered it. "Let me see," said she; "surely it was a large spoonful Edith told me to give—yet all that was in the phial doesn't fill the spoon. Surely I can't be wrong: no—I remember she said a large spoonful, and we didn't talk of any thing else—so I must be right." But Mary still hesitated, till, hearing a sudden noise in the court-yard, which, she conjectured, was her mistress returned, and as the child was getting worse every moment, she leaned back its head, and, forcing open its mouth, compelled the patient, though with difficulty, to swallow its death. The draught was taken; the rigid muscles relaxed, and for a minute the child lay motionless in her lap; but in an instant after, Mary could scarcely suppress a shriek at the horrid sight that met her gaze. The eyes opened, and glared, and seemed as if starting from the head—the fair face and the red lips, were blue, deepening and deepening, till settling in blackness—the limbs contracted—the mouth opened, and displayed a tongue discoloured and swollen—then came a writhing and heaving of the body, and a low, agonized moan: and, as Mary looked almost frantic at this dreadful sight, Edith's words, when she had given her the phial, "that there was enough there to kill," suddenly occurred to her—and then, too, came, with a dreadful distinctness, the remembrance of the true directions which Edith had given. It was nearly noon the next day, when the under-sheriff entered the room to ask if their opinions were yet unanimous. The galleyman still refused. "That for ye, coward," said Tyler, striking him with the flat side of his bared weapon. Oakley aimed another thrust which was again turned aside, and the smith, now flinging down his sword, seized upon his right hand and wrenched the dagger from its grasp. After a short struggle, Oakley fell heavily on the pavement with the blood streaming from his mouth and nostrils. HoME萝拉泷泽第4部资源
ENTER NUMBET 0016kqxiwq.com.cn fhchain.com.cn nyftmm.com.cn www.ncchain.com.cn pinfit.com.cn www.t51d9.net.cn www.szlddq.com.cn www.slsxsw.com.cn uwit.com.cn qyzenw.com.cn
