If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Sharp MFP BP-50C31 can not print from all pc but can scan
[Misc]
Hi
Sharp MFP BP-50C31 can not print from all pc but can scan, unable to print nic page when connected to the network, still can ping
I have a printer at my client place, BP-50C31. I label it as printer A using ip A. For a few month now, it having an issue of cannot print from all pc. Upon checking, using 1-1 connection printer no issue. Also ping the printer is ok and scan also ok. But when try to print the nic page or machine status page, the machine will hang and not able to print the configuration page but when I unplug the network cable, it will print just fine of the configuration page. I have try swap machine (both are of the same models), I relocate the printer A into location B using ip B and it is doing just fine. But when I relocate the printer B into location A using ip A, it will have the same issue. Currently, we try change the ip A into different ip at location A, 3 times, when changing ip at location A, the printer A will be fine for temporary, then in some case 1 month happen again, then change different ip, 2 month happen again.. and so today as we had changed into new ip number 3 on last november 2024..it happen again.. what could have cause this issue? Additional info, when first happen and i relocate machine, i also did test using ip A at location B into the printer B, and it also hang at those location B but when I put back the original ip B, it is ok. Also have tried swap machine permanently between 2 locations, the problem place still happen with different printer but at the other place with the problem printer is doing ok. Thanks for any assist. Have consult the customer networking person, their checking on their part will be saying their network no issue. sigh. Got any simulation or setting I can do maybe to checking on printer side..
How are the computers printing? And also how many? If they're going through the server, then it could be a server issue. If they're printing locally, I would point it to one PC causing the issue. Also, have you reset the NIC, and then put the info back in? Could clear image memory in sim 66-10, as well.
Pick your poison
A) Something is using the same IP
B) There is a defect with the LAN cable or LAN port or the electrical section of your customers.
C) Fix the network negotiation
55-03
SW6-1 Negotiation: 0 = Auto, 1 = Manual (see below)
SW6-2 Ethernet Link Speed: 0 = 100Base TX, 1 = 10Base T
SW6-3 Ethernet Duplex Mode: 0 = Full, 1 = Half
SW6-4 Ethernet 100/1000 Link Speed: 0 = 100Base TX, 1 = 1000Base T
Also there is a note about 192.168.0.xxx network that mess wit the copier, you need to update the firmware and the NIC firmware.
If the SNIC version is 01.03.01.00, IP address conflicts may occur if you install the MFP on a network with the IP address 192.168.0.xxx.
In the SharpONE, the SNIC firmware 01.04.01 is available in the download center for the corresponding models.
The update can be installed like normal firmware via SIM49-01.
When it happen, the computers will not printing and the job will forever spool at the computer. It will happen to all computer connected to the printer regardless of how many. It is printing locally. If one pc causing the issue, they have another mfp of the same model and it is printing just fine. have done reset nice also same. 66-10 also same.
Pick your poison
55-03
A) when ping and unplug the network cable from the machine, ping not no reply. suppose if something is using the same ip, when unplug the network cable, ping will have response.
B) customer IT tech have change to differ location internally to try differ port with new LAN cable, next day still happen and so temporarily change to differ ip for the sixth time
C) thanks for the info about network negotiation, after change into new ip for the 6th time for temporary solution, i had done 6-2, 6-4 and 34-3 .. will try to add later about 6-1 and 6-3
about the firmware update , the machine is on auto remote update , simulation 26-29, and so the machine is updated to the latest firmware.
4th time happen customer is using ip 10.21.25.80 , currently havent found the cause and again temporary solution by customer IT tech is change to another new ip again. still under monitoring.
yep.. it is in auto update.. and checking on screen, machine done updated to latest SNIC. In addition, I have swap machine with same model, only in that department happen
In total so far i have taken care of this client, therea are 4 machine having the same issue. and thus today another dept have the same issue , 3rd time for this dept, havent inform their IT tech yet for a meeting. Attached is the sample picture of machine cannot print nic page when it happen and showing those error.
Wait, so it's happening on multiple machines at the same customer now? When they change the IP, is their IT reserving it so NOTHING else can take it? Had the issue the other day where a phone was taking the IP and it was randomly letting print jobs partially come through, they would print a page or two and then nothing would happen. Ping test was alllll over the place. Mysteriously it just stopped when a bunch of people left for lunch.... Their IT reserved the IP and it stopped entirely.
hi guys..thanks for all the help..after few years monitoring, customer IT have tried to change the smtp setting of their own during the period of troubleshooting, which led to believe the ip not able to print..i dont have the reason for why smtp causing this but so far so good..after change to their new smtp setting, no more issue have happen.
btw , this environment is on government based operation setup
A favorite resort of the foreign residents of Yokohama during the summer months is the island of Enoshima. It is about twenty miles away, and is a noted place of pilgrimage for the Japanese, on account of certain shrines that are reputed to have a sacred character. Doctor Bronson arranged that his party should pay a visit to this island, as it was an interesting spot, and they could have a glimpse of Japanese life in the rural districts, and among the fishermen of the coast. "But as we are in for it," he continued, "we must make the best of the situation, and hope to go through in safety. Many a strong ship lies at the bottom of the sea, where she was sent by just such a storm as we are about to pass through, and many another has barely escaped. I was once on a ship in the China seas, when the captain told the passengers that it would be a miracle if we remained half an hour longer afloat. But hardly had he done speaking when the wind fell, the storm abated, and we were safe. The typhoon is to these waters what the hurricane is to the West Indies; it is liable to blow at any time between April and September, and is often fearfully destructive. OPIUM-PIPE. OPIUM-PIPE. "Surely your ladyship knows Dr. Bruce!" Hetty said with a vivid splash of colour on either cheek "A little time ago I understood that Dr. Bruce----" "I require that everywhere a strict investigation shall take place into the conduct of the soldiers with regard to the life and property of the civilian population. "Where were they buried?" They all pressed forward. "Count out. That's the only fair way," shouted the boys in the center. "Now, there's three loaves o' bread for the Sargint," said Harry, laying them down on a newspaper. "There's three for the Corpril; there's three for me; there's three for you." "'T?un't peas, thick 'un," Vennal would break in uproariously, "it's turnips—each of 'em got a root like my fist." At this moment of perplexity, some medicine, that she had obtained from Edith, occurred to her, and, with a feeling of confidence, and almost of extacy, she took a phial from a shelf in a cupboard where she had placed it, and, pouring out the contents in a large spoon, hesitated an instant ere she administered it. "Let me see," said she; "surely it was a large spoonful Edith told me to give—yet all that was in the phial doesn't fill the spoon. Surely I can't be wrong: no—I remember she said a large spoonful, and we didn't talk of any thing else—so I must be right." But Mary still hesitated, till, hearing a sudden noise in the court-yard, which, she conjectured, was her mistress returned, and as the child was getting worse every moment, she leaned back its head, and, forcing open its mouth, compelled the patient, though with difficulty, to swallow its death. The draught was taken; the rigid muscles relaxed, and for a minute the child lay motionless in her lap; but in an instant after, Mary could scarcely suppress a shriek at the horrid sight that met her gaze. The eyes opened, and glared, and seemed as if starting from the head—the fair face and the red lips, were blue, deepening and deepening, till settling in blackness—the limbs contracted—the mouth opened, and displayed a tongue discoloured and swollen—then came a writhing and heaving of the body, and a low, agonized moan: and, as Mary looked almost frantic at this dreadful sight, Edith's words, when she had given her the phial, "that there was enough there to kill," suddenly occurred to her—and then, too, came, with a dreadful distinctness, the remembrance of the true directions which Edith had given. It was nearly noon the next day, when the under-sheriff entered the room to ask if their opinions were yet unanimous. The galleyman still refused. "That for ye, coward," said Tyler, striking him with the flat side of his bared weapon. Oakley aimed another thrust which was again turned aside, and the smith, now flinging down his sword, seized upon his right hand and wrenched the dagger from its grasp. After a short struggle, Oakley fell heavily on the pavement with the blood streaming from his mouth and nostrils. HoME萝拉泷泽第4部资源
ENTER NUMBET 0016www.huiyib.com.cn www.liwibw.com.cn www.guasheng.net.cn kokwz.net.cn www.tuuujy.com.cn ogwqmd.com.cn www.samuji.com.cn xcchain.com.cn wrchain.com.cn www.woooyoo.net.cn
